brian ploskunak
I couldn't find where this one was addressed. I have a generator that will not be a SDS, solid neutral at the MTS with the neutral and EGC not bonded together at the generator. The generator will be on a concrete slab. Should I just bond the slab steel to the equipment grounding conductor and the frame of the generator?
Or, should I do a supplementary ground rod and bond the slab steel, the generator frame and EGC together?
Do I size the ground to the slab steel the same as the EGC?
