Richard Cummins
- Chattanooga TN
We currently use a grounding Halo made up of 2 1/2" x 1/4" x 10' section of bus bar. We connect all MCC's and Swithgear on both ends of the gear with a 4/0 AWG cable to the grounding Halo. We ground all other metal surfaces to the Halo with the appropriate sized grounding conductor. We use a pressure lug on the cable and bolt the lug to the grouinding Halo. We ground the Halo with a 4/0 AWG cable to the metal base of our building's Stainless Steel ground pad with a lug on each end. I have had an electrical inspector tell me that the connections to the grounding Halo are considered splices NEC 250.64 (C) (1) and I need to use a non reversible connection means to the grounding Halo and ground pad. We use a 3/8" bolt with a flat washer on both sides and a compression washer before the 3/8 nut. What is your opinion?
