Re: Grounding Impedance Test
Originally posted by don_resqcapt19:I thought that a ground impedance test measured the impedance of a fault return path back to the power source.Don
A ground impedance test measures the resistance between the ground rod and planet Earth. More specifically, it measures the resistance between the point on the ground rod at which you connect the GEC and the dirt that is far enough from the rod to be representative of the Earth as a whole (actually not the whole Earth, but just the local area).
It took me a long time to catch on to one aspect of ground rods and the NEC?s statements about a 25 ohm resistance. Let me try to explain what I (only recently) figured out. We all know that when you place two resistors in parallel, the net total resistance is smaller than either of the resistors you started with. Place a third or fourth or fifth in parallel, and the total resistance continues to go down.
Now let?s play a mental game. Imagine two rods stuck into dirt some distance from each other. Imagine using a voltage source to force current to flow between the two rods. (At this point, you are imagining part of the Fall of Potential Test.) Question: How does the current go from one to the other? And the answer is:
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">From a point on Rod #1, one inch into the dirt, draw a straight line to Rod #2, again one inch into the dirt. That is the first path for current flow.</font>
<font size="2" face="Verdana, Helvetica, sans-serif"></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">From a point on Rod #1, two inches into the dirt, draw a straight line to Rod #2, again two inches into the dirt. That is the second path for current flow, and it is in parallel with the first.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Now pick any point you like on Rod #1 and any point on Rod #2, and draw a straight line between your two points. That is the third path for current flow, and it is in parallel with the first two. Keep this up until there are no more straight lines to be drawn.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Now start drawing curved lines. Draw curved lines that start at Rod 1, go downwards into the dirt (i.e., deeper than either rod), and curve back up to Rod 2. You get a whole bunch of parallel paths that way too.</font>
The net result of this game is that if you have a chunk of dirt that is deep enough, you will get an effectively infinite number of parallel paths through the dirt. That gives you a net resistance through the dirt of nearly zero ohms. In other words, the resistance of the dirt between two rods 8 feet apart is the same as the resistance of the dirt between two rods 80 feet apart.
