blumenstein
I am a Fire Captain with Salem Fire Department, and a HazMat Technician with Oregon?s Region 13 Hazardous Materials Team. I would like to correspond with anyone who is aware of regulatory information dealing with establishing a ground (to earth) that has greater than 25 ohms resistance (for special circumstances).
I am gathering information for a fire department-based class on grounding and bonding as it relates to grounding a damaged transportation tanker in the presence of flammable vapors.
I have been advised that a 10 to 100 megohm cable should be used to prevent a spark when grounding in the presence of flammable vapors (Graham Hearn ? Wolfson Electrostatics, University of Southampton).
Presently we are testing ground rods placed at emergency scenes to assure that we have sub-25 ohm ground to earth (one for the damaged tanker and one for the rescue tanker), and use low impedance cables to connect each tank to ground (before we electrically bond the tanks together).
First, is anyone aware of a regulation that allows the creating of a high-impedance ground? Since it appears we don?t need a sub 25 ohm ground, it would be much easier to create a ground that had 500 ohms or less resistance (It will be faster and safer to create in the field).
Second, where would I find a 10 to 100 megohm cable suitable for connecting a damaged tanker to a ground rod? I am looking for something that would be durable and have a 50 to 100 foot reach.
Any assistance would be appreciated.
Larry Blumenstein, Captain
blumenstein@comcast.net
