My mother purchased a home built in 1942 which has no grounding at the service or the two sub panels.The upper floor has the old cloth covered two conductor branch circuits and the lower level has a very old romex type of wire with a small ground wire.I figure that the lower level was either remodeled or was originally wired at a later date than the upper level.All of the ground conductors are landed on the neutral buss with the neutral wires and someone had ran a #6 solid copper ground wire from the electric water heater and dryer to the neutral buss at the service and bonded the water heater and dryer grounds to it.
The feeders to the sub panels run through interior walls and a poured concrete wall so I can not feasibly run a new ground with them.I can bond the service to the city water line but I am concerned that if I do I will be creating net currents/electromagnetic fields in all of the circuits that have the neutrals and grounds bonded at the sub panel,plus the old wire is very brittle, if moved too much it cracks the old insulation.
My electrical experience is in the commercial/industrial field so I an not sure what to do about this, to make it as safe as possible, without ripping out the lath and plaster walls and rewiring the whole house.
I will be very thankful for any insight or information you could provide reguarding similar situations.
thanks,
Bob.
thanks,
Bob.
