I am currently working for an engineering firm in which we have our own panel shop (UL508A), and there has been a couple issues concerning grounding in which I am trying to resolve:
1. When attaching DIN rail to the backplane do the screws used have to be drilled and tapped or can self tapping screws be used in order to maintain a proper ground for grounding terminals attached to the DIN rail.
2. The last inspection we had, the inspector told me that the new code requires the enclosure doors to be grounded (with a conductor) even if the doors use a continuous hinge. In the past the continuous piano hinge was an acceptable grounding method and no additional ground conductor was necessary.
3. Is there a minimum size wire for grounding inside the panel, or is it sized by load of the device.
Thanks in advance.
Steve
Thanks in advance.
Steve
