grounding in high rise
New to forum..main service enters building..sub panels and xfmrs on other floors..in electric rooms there will be a ground bar..tied to ground ring..bldg. steel..other ground bars...my question is ..can I ground my xfmrs to the ground bar or do I have to supplement it somehow..I.e. the ground bar and bldg. steel?
If the building has building steel frame construction you would use the steel in the vicinity of each transformer as the grounding electrode.
Welcome to the forum. :)
