I'm do a ground test in patient care areas, (patient vicinity)between a reference point and any exposed conductive sufaces and receptacles grounds.I'm using a fluke 87 trying to reach a resolution of 20%. Less 20 m Vrs + or - 4 mV into 1000 ohms and less than 0.1 ohms + OR - 0.02 ohms.
The readings I'm getting are between 16.0 and 19.0 on millivolt ac and .01 to .03 on resistance
leads are factored out grounds are tight, reference point is a cold water pipe and panels are bonded together as per NEC 517-14 thinking a more sensitive meter may do a better job any professional input would help. thank you dcv
