Energy-Miser
- Maryland
The 2.5" EMT is being used to carry the ground to a subpanel, from 200 amp fused service disconnect. The neutral is bonded in the subpanel to the EGC in an existing installation. Should I separate them and isolate the neutral from the ground? There is no easy way to draw a new equipment grounding conductor from the service disconnect to the subpanel. Thanks, E/M.
