Grounding Main to Outside Disconnect
buddyearl
Hermitage, MO
Teacher
Upgrading our system and will be installing a meter/disconnect on the exterior and replacing the main panel. Currently there's no ground from the main to the meter. The meter has a ground wire going to a rod, but not sure how deep the rod is, so will replace with two new 8' ground rods. The feeders run through metal conduit, but there's two 90 degree turns and it's run through the floor joists under drywall, so would be hard to pull a copper ground wire through. I want to run the copper ground a different route out. Can I attach it the first ground rod, then to the second ground rod, then to the meter disconnect? Thank you.
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Reminder to all members, if you see a questionable post, feel free to report it by clicking "Report" at the bottom left corner of the post.
