Grounding meter base
Champy2020
New User
Central Illinois
Construction
I set a meter base, where utility power is coming in. I set a ground rod, and bonded from the ground rod to neutral inside of the meter. From the meter, the load conductors run to a feed through panel that has a 200a breaker, then goes to supply power for a couple breakers. Then off the load side of the feed through lugs I will be feeding a 200a panel inside of the house. What is the correct way to ground the feed through lug panel, as well as the panel inside the house?
The best way is to have an electrical contractor pull the permit, and do the installation per code. We are unable to assist DIYers per forum rules.
