I am working at a high school where 5 mobile home (trailer) type classroom outbuildings are being installed. The power company would not provide 5 drops for us. Instead they made us install a distribution panel so they could provide one larger service drop. The distribution panel has a main breaker and 5 branch breakers. We will be bonding neutral and ground at this panel. The question is: Do we have to run a separate ground to each trailer? Currently the drawings show the 2 phases and a grounded conductor from the distribution panel to each trailer. At each trailer, a ground rod will be installed and the neutral and ground bonded just like a service entrance in the usual means.
Should we be including a ground wire (4th wire) in these branch service feeds?
