Paul Morocco
Can the Radio Mast be grounded to the Steel Tank or is a separate grounding conductor require as per 810.21?
We are feeding the Radio with a cat 5 ethernet cable in a 1 inch rigid conduit. As Per 821 (F) Can the conduit be used To Bond the Radio Mast to if we bond to the ground rod at the tank base and bond to the radio mast at the top of the conduit?
[ June 28, 2005, 09:36 AM: Message edited by: Paul Morocco ]
