For the grounding of metal enclosures of equipment in a computer room, does this fall under effective ground fault path?
The metal casings of computer equipment, racks, and cabinets are going to a grounding bar on a plywood wall in the room. This grounding bar has a grounding conductor going directly to building steel. What is the purpose of this grounding?
What section of grounding does this fall under? Is this supplemental or auxiliary grounding.
