sbutler
- North Charleston, SC
Please tell me if I am interpreting the code correctly. When using a 3-pole ATS, a ground rod is not required (nor desired) at the generator as the neutral is not being switched and is sharing the neutral from normal power. Doing so could create a ground loop. On 4-poles switches with the neutral being switched, a ground rod is required as this is a seperatly derived system.
Thanks to any and all replies.
