kentpowell
I am installing a new meter center. There is a 1600Amp main switch coming in from the power company's transformer. The main switch has a four buss bars--three phases and a neutral--which feed thru to the meter stacks on each side.
There are 3 stacks of 4 meters each on each side of this main switch. Beside each meter is an 100Amp breaker to serve the individual user.
I think I should be bonding at the Main switch; then seperating the earth ground and the grounded neutral conductor in the meter stacks.
Since the equipment has no provision for earth grounding in the meter stacks ( as provided by the manufacturer), it gives me pause to wonder if I am correct?
