Does the running the equipment grounding conductor that is part of the phase conductors that are routed from the motor control center ground bus to the motor frame ground lug satisfy NEC Article 250.112 (C) and (L). I have heard some inspectors require a separate ground be run from the motor frame to the ground grid. Is this a vailid requirement?
