timm333
- Minneapolis, MN
- Electrical Design Engineer
I have to ground an outdoor light fixture which does not have an internal grounding lug. I was thinking to put grounding lugs on outside of the fixture (on metal frame.) The back cover of fixture is a separate assembly which connects to the main assembly by screws. So I was thinking to use two grounding lugs; one lug for the main assembly and one for the back cover, and then connect the two lugs together.
The grounding lugs should be mounted at the bottom of fixture so that water does not go inside the fixture. But the problem is that we are mounting the fixture facing down, so the glass frame of the bulb will be at the bottom and all metal will be either on top or on side. So if I put grounding lugs on top or on side of the fixture, the rain water will enter into the fixture and the fixture will no longer be water-tight.
Any ideas how to ground the fixture and still maintain the water-tightness of the fixture? Maybe I can use something like water-tight glands?
