Grounding of Under Cabinet Light Fixtures
JB1
Is it code compliant to connect from fixture to fixture using 14/2 fixture cord w/o ground? Cord to be supported under cabinet. 14/2 NM panel feed to enter into 1 fixture through the wall into the back of the fixture. The 14/2 fixture cord to be connected here and run to the other fixtures. Or is a ground wire required from fixture to fixture. The light fixture is a 2' flourscent.
All the fixtures need to be grounded, if you think about it it may be MORE of a hazard to ground the first fixture and not the second fixture. A ground fault in the second fixture would not clear, causing a situation where if you touch the two fixtures you would become the path to ground. :mad: Not a good idea.
I agree with acrwc10. 2' flourescent light fixtures with exposed conductive parts need to be grounded. Take a look at Part V of Article 410 for the grounding requirements for luminaires.
By the way welcome to the forum.:)
Chris
Dennis Alwon said:
You cannot use fixture wire to run between fixtures. It is not approved for that purpose.
Agreed, you can't use fixture cord or lamp cord for the permanent wiring between two flourescent strip fixtures.
Chris
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.
