We have replaced a subpanel in a very old electrical system that has no ground to the main panel and no grounding rod(s). Long story short -- we are not now upgrading the main panel and have no convenient location to install the ground rods at that location.
I'm thinking that I run a new ground wire to the main panel from our new subpanel, connect this to the existing neutral bar there, but run the ground rods from the subpanel location. Assuming that all the grounds are connected but still floating (separate from the neutrals) at the subpanel location, is there any problem with this setup?
Should of taken a pic of the existing main panel ... its quite something ... I'll try and get some Monday
Thanks
Thanks
