Grounding or bonding a temp generator
82angelfan
Hesperia, Ca
I am connecting a large temp generator to a new building so that Mechanical can do start-up, and also to climatize building for casework. Permanent power is 6 weeks out. Can I bond my genset to my electrical room bus bar next to MSB in lieu of driving a ground rod in the brand new parking lot. Ground bar attaches to Ufer, water, steel and a ground rod in a planter. Los Angeles if that changes anything.
It sounds like the current building GES is present and in place therefore you would be required to use it.
