We have a situation where there is an outdoor light fixture that was installed without a ground. It also has no conduit run to it and is installed on a decorative foam door frame with only the separate stranded neutral and hot wires protruding through a hole in the foam to feed the fixture. We cannot find the junction box that feeds the light since it is apparently buried beneath the door frame. I was wondering if anyone had any suggestions. Due to the fact that hot and neutral wires are not protected and we can't find the J box, is our only option to run some new conduit through the wall from another known J box?
Does anyone have any other ideas that will meet code? Thanks in advance.
