Grounding plastic water line?
JKinPA
It was suggested that I ground the water line where it meets the pressure tank. The water source is a well which is completely plastic pipe. The only metal in the water system is a pex manifold, pressure tank, and hot water heater. Why would you need to ground the pressure tank? Can you count on the water in the plastic tubing to make a connection to the well casings? One other point I might mention is that there are already 2 ground rods.
You only need to bond a metallic water system. Isolated metal sections of pipe or components do not constitute a system.
:wink:
Sorry, couldn't help myself :grin:
Roger
petersonra said:
You should have used plastic wire, instead of copper. Red Tag!
I think the inspector wanted monofilament :wink:
Roger
