Grounding portable welders, light plants
Jose Renteria
New member
Is the grounding of portable equipment that is in temporary use required to be grounded with a ground rod or to building steel, per the NEC Code??
Would you ground a Sucktion truck, an Air Compressor, a portable AC unit?
