I have 25kva 120/240 service transformer. I measure 126 on each phase and 252 between the phases. When the transformer is connected to a sevice entrance there is a potential difference between the transformer's nuetral and the sevice entrance ground of 3 volts. This 3 volts cause arcing on the casing of the well, which is grounded, fed of this sevice. why there is 3 volt differce between the two grounds? How to get rid of this 3 volt differential ???
