On a current project, my inspector is requesting that we install a ground wire #6 or larger from the ground rod installed in the pull box to the steel cover with a stainless steel bolt (leaving a loop to remove the cover). He is stating this is a requirement in the NEC 250 section. I can't find it anywhere.
