Do pull boxes and troughs have to be grounded or bonded in a conduit run.
T transman2 Senior Member Location Brooklet,Ga. Jul 29, 2013 #1 Do pull boxes and troughs have to be grounded or bonded in a conduit run.
ptonsparky Tom Location NE (9.06 miles @5.9 Degrees from Winged Horses) Occupation EC - retired Jul 29, 2013 #2 Yes, raceway type, voltage, current rating of feeder protection, and specs will determine the details.
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician Jul 29, 2013 #3 transman2 said: Do pull boxes and troughs have to be grounded or bonded in a conduit run. Click to expand... In many cases if you have a metallic conduit the raceway can ground the PB or trough.
tom baker First Chief Moderator Staff member Location Bremerton, Washington Jul 30, 2013 #4 Yes and no for pull boxes. See 250.148 (a change from 2005 NEC) For a trough (this is not a code term) so you may be referring to a wireway, voltage and KO type dictates if bonding is required.
