Silv14
New User
- Oregon, USA
- Fabrication
Hello,
I'm redoing the wiring in my shop to have a safe updated electrical supply, and I've become a bit confused about where you derive a ground for a 120v single phase subpanel from a 4-wire 3-phase 'high leg' Delta main.
For a little background, the building is from the 50s (which I'm sure you could deduct from the 4-wire delta,) and it had a whole mess of several different fuse boxes (some 3-phase, some single-phase, some 3-ph converted to single-ph, and a whole lot of dust and corrosion between them) along with one 120v sub panel, and another 120v sub panel in a different part of the building, all fed from a honking 3-ph 150amp breaker acting as a main disconnect. I'm using the building for automotive fabrication along with machining, so I have several 3-phase motor loads, and only had one 3-phase fuse box. I upgraded to a Siemens MLO 200amp, 24 spaces, and used the 150amp main breaker to feed that load center.
Now I was beginning to start rewiring in some of my circuits, and I got a bit dumbfounded on where the ground wire ties in to the system. I can't seem to find a straight answer for this. Do I need to run a secondary wire to the neutral lug from the main breaker enclosure, or do I just tap into the neutral bus twice? Or do I need to corner ground one of the legs? There appears to be several bare ground wires already going to the neutral terminal in the main breaker enclosure.
Additionally, I found some mention where it says the NEC does NOT want you to install 1-ph circuits in a 3-ph panel. Is that the case? I'm aware of the 208v Line-B (in my case) to Neutral factor, and that I would have to skip these positions in the box should I place a 1-ph circuit. If it is indeed illegal to power 1-ph 120v circuits from the 3-ph panel I can always add a subpanel for those circuits.
I can post photos as well if that's helpful.
I plan to have all of my work inspected to ensure legality at the end of the project.
Thanks in advanced to all of you sparkies.
