Grounding Question
R2006
PENNSYLVANIA
hi guys a quick question.
A while back you were talking about a problem with running a ground wire through a piece of emt mounted to the wall. There was a name for this problem. But of course i cant remember it a little help please.
thanks.
thanks.
Is it in regards to a grounding electrode conductor? If so, you must bond both ends where it exits the metallic conduit. Hope that helps.
R2006
I don't mean to change the subject here,but I'm also from PA and I was wondering how you got your masters. The only reason I'm asking is that I was unable to find any sort of state licesnse. If there's something I missed please let me know.
Thanks
Mike
Hi Mike
In Pa You Have To Obtain A License For Each Town Ship. Im Over By Philly And Have A License In Several Townships Around Philly. I Carry About 10 Licenses. Its Early Hope My Spelling Isnt Too Bad.
You Have To Be Insured And In Some Instances Your Required To Test But Ussually If You Have Certain Ones The Other Township Will Just Issue A License Based On That.
Good Luck.
