I recently had a home inspection done on a house that I would like to purchase. The house was built in 1993. The home inspector found the following problem and I would like to have someone comment as to whether or not this may be a potential problem.
- The electrical system has multiple grounds to water pipes at the water heaters and a ground rod at the main service entrance. This appears to have step potential and should be addressed by an electrician and repaired if needed.
These are gas water heaters and I believe the ground goes to the cold water side. The gounds at the water pipes do go back to the main breaker box and there is a ground from there to a lightning ground.
Any help is greatly appreciated.
