Re: Grounding Quiz, by Mike Holt
Question #33 asks if you are more likely to be electrocuted in salt water than fresh water.
I was always under the impression that the reason that you can get electrocuted in the tub is because the salt from your sweat makes the bathwater more conductive. Otherwise freshwater is a really bad conductor.
Based on this assumption, swimming in a fresh water lake or river and having the power pole tip into the water some distance from you probably wouldn't be too much of a hazard. Your sweat is localized and would stop shortly after the swim began unless the water is hot. And the current has to get through all that insulating H2O to get to you.
A body of salt water would behave somewhat like a big grounding system, taking the current to ground. Even if it didn't, it would likely keep your whole body at close to the same potential, limiting current flow through you. In other words, it shorts you out.
The tub hazard is due to limited water volume, your sweat salt, and that metal pipe underfoot tied to the grounding system of the house.
Which begs another question, what if the piping in the tub, in and out, is all PVC?
Matt
