Somebody know what is the correct grounding method for a Data Center with a raised floor and isolated ground?
Where do you ground the racks?? If you connect the rack to the non-isolated ground, maybe interconnect the grounds, because the racks equipment (servers, switch's, etc) use the isolated ground and this one is connected to the metal enclosure of the equipment.
Furthermore, Where do you ground the metal supports of the raised floor??
