david.mullins
- Santa Barbara, CA, USA
- Electrical Engineer
We are building a large motor control system. It has 8 motors in an enclosure and they can run in regen mode for extended periods of time. The motors are servo controlled by listed AC Brushless motor controllers. They have outputs for regen current when the motors, acting as generators, drive the controller internal supply bus above about 650V and can go as high as 1000VDC. We are mounting the regen resistors (load resistors) in a well ventilated metal enclosure mounted on top of the metal controller enclosure, which is about 7 feet tall. There will be two leads for each resistor, + and -, neither of which is grounded. The resistors are in metal tubes and sealed with potting compound. In order to minimize cabling, we will wire from the lower controller enclosure to the top regen resistor enclosure with paired cables, hopefully 2 or 4 pair per cable.
In this configuration, can I run a single ground wire from the lower enclosure to the upper one or do I have to have a grounding conductor in each cable?
P.S. I know the statement of the problem can be the biggest source of contention on these forums so I have tried to carefully word it. Please ask me to clarify anything you have questions about!
