Hello,
I have some new 14/2 cables + speaker wire installed near foam insulation. I have noticed that the installed foam insulation carries static electricity, which i do not want for the low voltage, and have some concerns about the line voltage. I wanted to know if this could be neutralized by grounding the foam once, or if the foam can be bonded to a piece of metal inside the walls, maybe to a sacrifical piece of metal.
I am not entirely sure how safe this is, but XPS foam insulation in walls all the time.
I have noticed that i can install metal mesh on the foam to neutralize the electric field (similar to a faraday cage), but would rather try to control or reduce the XPS insulaton charge if i can.
Thanks
Thanks
