Nardie
- North Augusta, SC USA
I am installing a new sub-panel fed from my main house panel. The new sub-panel is a 240V/125A panel without a main breaker, and the neutral and ground bus are connected. I plan on using 2 #2/0 with a #4 neutral and #4 ground. The cable will be direct buried, so no conduit. Do I need to install a ground rod for the new sub-panel, or make sure the neutral and ground bus in the new sub-panel is not connected. I want to avoid having a parallel path to ground thus creating circulating currents. I have looked at article 250.32, and I'm a little confused. Exhibit 250.18 shows no ground rod with the neutral and ground bus separate. Exhibit 250.19 shows a main circuit breaker with an isolated neutral and ground bus with a ground rod. So what should I do. Thanks for the help.
