Power2engineer
- US
- EE
Trying to find answer to NEC requirement for Solar PV carport PV structure grounding & bonding.
NEC 690.47 (A) Building or Structures supporting a PV Array shall have a grounding electrode system installed in accordance with Part III of Article 250.
PV array EGC shall be connected to the grounding electrode system of the building or structure supporting the PV array in accordance with Part VII of article 250. This connection shall be in addition to any other equipment grounding conductor requirements in 690.43(C). The PV array EGC shall be sized in accordance with 690.45.
My questions.
1. Minimum number of canopy (structure) columns required to be grounded using ground rods bonded with grounding conductor to canopy columns?
2. In a Parking lot with multiple Canopy structure should the grounding of each canopy structure be tied together using a bare copper ground wire in the trench? How is this ground wire sized?
3. Is it necessary to tie these Canopy structure grounds to building ground grid (ground loop)?
4. What are the differences in grounding requirements for ground mounted canopy vs garage roof top canopy structure?
5. What are lightning protection requirements for Carport structures?
My questions.
