davidsonkiss
- Charleston, SC
I have an above ground pool with a 120V pump motor. I installed a weather proof switch and duplex receptacle with WP in use cover on a post next to the pump. The receptacle is fed by a GFCI circuit breaker. The pump came with a standard 120V/15A plug installed from the factory. Also ran#6 from the ground lug on side of the pump motor to the pool frame. It should also be noted the sides of the pool are 48" Getting ready to have it inspected. Am I missing anything? Would appreciate any input.
Thanks,
Dave
Thanks,
Dave
