john2016
- California
- Electrical Engineer
I'm working in a building where there are 10 floors. Each floor has it's own electrical room with a grounding ring in each room that grounds 6 panels within the room. The grounding ring is then connected through each floor and then grounds at the main electrical service on the first floor.
My question is the existing grounding ring properly grounded the way it is connected in these pictures? The panels are mounted on the unistruts and the ground wire is secured to the unistrut. The ground wire is always touching the metal ventilation grill.
