Grounding rode capacity
Jide A.
New York, NY
i want to know the capacity of a grounding rod. whenever i ask about how many grounding rod i would for a project, most engineers tell me 2 or 3 but never give a full reason why. i want a better understanding of this. i s it okay to just have 2 or if there are no rules install 20 if i wanted?
thanks.
Jide A, your profile says engineer. Are you in the electrical trade?
But to answer your question you can have as many as you like, in no case does the NEC require more than 2.
Most times when I ask design engineers why they designed the GES the way they did I never get a good answer either.
But as Iwire points out, the NEC never requires more than two.
Roger
