cirtcele1
- United States
I have a pole barn that is supplied by the main panel in the house. The feeders are connected to a two pole breaker in the house. They have only the two hot conductors and neutral conductor running to the pole barn panel branch panel main breaker. A seperate grounding rod has been installed at the pole barn. The part i'm a little unsure about is the neutral has been isolated in the pole barn branch panel. From looking at the current 2011 code this is not correct?
