rsamaniego@viasyscorp.com
New member
I have a traffic signal pole with the service equipment mounted on the pole and the ground from the meter disconnect is running thru a ground rod directly to the cabinet about 10' away. the meter and disconnect and conduits are bonded as is the traffic control cabinet. Is this acceptable. Also the pole itself is grounded but to a separate ground rod.
