Grounding Siding - Metal Roofs
upstate
New User
ny
I have read through a lot of the old discussions - what is the latest with NEC or any code about grounding aluminum siding or metal roofs ?
Has anything been updated?
Unless there is a pool within 5' of the siding and roof then there is and never has been a reason to ground it- afaik
Even if you do do it how do you know that all of the siding or the roof metal is effectively bonded? Ground out a hot at the farthest point from the bond?? It is a silly notion started by some folks who need to get a life.
An alternate path is to join electrical forums. That way, even if you don't have a life you are either helping or learning.
