ddecant
- Groveland California
Are you required to ground a slab floor in CA if a grounding rod is used?
Here the slabs are not in contact with the earth,there has to be a vapor barrier between the two, but the slab isn`t bonded.Even the ones that have reinforcing mesh in them.I have wondered about these types before in regards to having a floor box or two installed and there is a steel tub in a bathroom.Both are in contact with the slab and there is a possibility of the slab becoming energized.Since concrete will allow you to get a severe shock when in direct contact with it.Why isn`t the mesh in a slab bonded ??? But a pool is .raider1 said:Why would you ground a slab floor in contact with the ground?
Chris
allenwayne said:Here the slabs are not in contact with the earth,there has to be a vapor barrier between the two, but the slab isn`t bonded.Even the ones that have reinforcing mesh in them.I have wondered about these types before in regards to having a floor box or two installed and there is a steel tub in a bathroom.Both are in contact with the slab and there is a possibility of the slab becoming energized.Since concrete will allow you to get a severe shock when in direct contact with it.Why isn`t the mesh in a slab bonded ??? But a pool is .
