I work for an electrical cabinet manufacturer and I want to be able to give the propper instructions for instlaling our equipment. Our products are installed outdoors and a they get buried a minimum of 2 feet into the ground. Sometimes for extra support of the enclosure, we sell customers a steel post similar to Unistrut that they bolt to the enclosure. The bolt holes in the enclosure are factory provided and are powder coated, thus there is no metal to metal contact, which would technically prevent bonding between the post and the enclosure. The enclosure has a ground lug which can be connected to a ground rod and grounding system by the installer. The post is galvanized steel and completely buried, and the bottom of the post extends 4 feet below the ground level, but I am concerned that the post would not have an adequate path to ground if it were accidentally energized separately from the enclosure. Is there anything in the NEC about what is considered propper bonding of steel support posts like unistrut? Would anyone suggest connecting a grounding terminal to the post and then connecting it to the enclosure ground rod and grounding system? Thanks in advance for your replies.
