From Eaton Spec Sheet.
Application Description
Electrostatically shielded transformers are used to protect sensitive electrical equipment from undesirable high fre- quency signals commonly generated by lighting, switching surges, motors, and SCRs feeding noise back into the line. An electrostatic shield, consisting of a single turn of aluminum foil placed between the primary and secondary winding, is used to provide from
30 to 70 dB attenuation of wide band line-to-ground (common mode) noise.
Typical uses of shielded isolation
transformers include:
■ Suppression of transients and noise which travels from its source to the sensitive load equipment.
■ Suppression of noise and transients at the point where the noise or transients are originating, thus preventing them from backfeeding from the source to the feeders.
■ Transform one voltage level to another.
■ Isolate one circuit from another.
