grounding terminations in panelboards
ndc81167
does anyone know of any code reference that requires only manufactures listed grounding lugs for the panelboard being installed
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
I agree with Trevor but I don't know anything that would make you use the manufacturers ground lug. If the holes are tapped and the number of threads (250.8(A)) are maintained then why not. I have seen single lugs added to panels.
iwire
Massachusetts
I agree with Trevor and Dennis.
Should be no problem but if the panelboard label specifies a grounding bar kit (which they all seem to) I can see an inspector pulling the 110.3(B) card.
