grounding terms help
larrywd
Equipment bonding jumper, system bonding jumper, grounding electrode conductor, main bonding jumper
I used to think I had these terms down-pat, but now I am unsure. Does anyone have an illustration or way to keep these terms straight in my head?
Thanks,
Larry
Twoskinsoneman
West Virginia, USA NEC: 2020
Facility Senior Electrician
Thanks,
Larry
Mike H has many awesome graphics of a lot if not all these terms.
Head over to his free graphics page
http://www.mikeholt.com/freegraphics.php?id=gvb
Brows through them :thumbsup:
Here's a good example.
bphgravity
Florida
The main bonding jumper & system bonding jumper serve the same purpose but for two different systems. They both connect the grounded circuit conductor with the equipment grounding conductor at a service or SDS.
MBJ = Service / SBJ = SDS
The grounding electrode conductor is used to connect a service or SDS to a grounding electrode (earth).
The equipment bonding jumper is used to connect portions of the equipment grounding conductor together to maintain the path for fault current.
