Grounding test well
anbm
TX
Designer
Is there a min. or max. number of grounding test well required especially when the building has lightning protection system with
several ground rods buried? How to meter the ground rod resistance or access the rod if there is no grounding test well installed at each ground rod?
Thank you.
