karl riley
Recent health researchers have found that grounding the body, particularly at night, has definite measurable health effects.
The question is how to do this according to NEC and safety in general. Some ground to a stake outside. But this I believe violates Code because it is not bonded to the building ground; hence it would remain energized if a fault with a hot source occured.
The other way is to ground to the grounding jack in a wall receptacle after checking that it is wired correctly. My question is whether there is still a safety/Code problem with this. If the hot contact were downstream from the connected person, I would think they would be safe. If the person were the contact point, then only the resistance to the grounding point would determine how much current went through them. Agree?
If a safety resistor were part of the grounding device, then the person might not have a lethal current go through them, but they would remain energized and if they touched a grounded surface then they would be in danger. On the other hand, this is always true in a Code compliant house.
Opinions needed. this has to be settled, since this is an important health breakthrough.
Karl Riley (still a moderator!)
