qlr
- United States
Hello to all,
I am new to the forum and thanks for having me. I have some concerns regarding grounding/bonding a transformer being used backwards. That is to say we are using a 240v delta to 208v wye transformer to go from 208v to 240v. I have fed the 208wye side as my primary with no neutral- just three ungrounded conductors. Normally I have connected a ufer, or some other GEC to xo and then to case of the transformer, and this is done on the secondary side. In the scenario we are using this transformer in there is no xo connection because it is the 240v delta side of the transformer. I bonded/tied the B phase to case ground and now I have equipment ground at my panel- at least on A & C phases. My main question is do I need to connect the case of the transformer to a grounding electrode ie: water pipe, rod, or other made electrode? I did some searches here on the forum but did not come up with anything related to using a transformer in this fashion. Any help would be greatly appreciated.
Thanks in advance!
Thanks in advance!
